How to Get Attribute Engineering Case Values in C#?
Hey folks,
I'm trying to figure out how to get all case values of an attribute in C#. Here's what I know so far:
If you've got a double-type attribute, it’s easy to grab the value in a specific UoM like this:
*Element.GetDbDouble(Attribute).ConvertUnits(DbDoubleUnits UoM)*
But when it comes to attributes defined as engineering cases, I thought I can get them like:
Element.GetValidDoubleArray(Attribute, ref output);
but Engineering cases seems not stored as arrays.
on the command line, you can do:
*q :DesignPressure('Case_1')*
*q :DesignPressure('Case_2')*
This gives results like `1960000 pascalg`, based on the project's default UoMs.
In C#, I was able to use `EvaluateAsString` to get the specific case values. Basically, I looped through cases built an expression for each:
for (int i = 0; i < attVal.Length; i++)
attValStr = Element.EvaluateAsString(DbExpression.Parse(Attribute.Name + "('Case_" + i.ToString() + "')"));
and then extracted the numeric part of the returned string. After that, I divided it by `100000` to convert it into `barg`. It works, but honestly, it feels like a hacky workaround.
What I really want to know is: does Aveva provide any direct method to handle this kind of thing? Something cleaner and more built-in?
Would appreciate any tips or ideas.
Thanks in advance!
