The Length attribute of the SBOL element has problem with syntax clash.
If we use "Q LENGTH" command, we will get a syntax error, and "Q LENGTH $Q" replies it need "(" next to the command.
This means that "LENGTH" will be recognized as "LENGTH()" function, not "LENGTH" attribute of SBOL.
All PDMS attributes and commands/functions name are unique, but this is an exception.
This is only one command/attribute name clash I know.
To prevent this conflict, we can use "ATTRIBUTE" command with round brakets, like "Q (ATTRIB LENGTH)".
Try the following style to prevent the problem,
var !a collect all sbol for ce
var !b eval (attrib length) for all from !a
