Hi
Is there a way to output descriptions of attributes via PML?
I have this macro, but so far it's just outputting an attribute and it's value for an element. I'd like an additional column, description.
!element = !!ce !outputDirectory = 'C:\Temp\test.csv' !allAttributes = true !pseudoAttributes = true !file = object file (!outputDirectory) -- Define Arrays !lines = array() !types= array() -- Attributes to Collect if !allAttributes EQ true then !types.append('attlist') endif if !pseudoAttributes EQ true then !types.append('psatts') endif -- Collect All Attributes to Array do !type values !types do !attribute values !element.$!type !value = !element.attribute(!attribute).string() handle any !value = 'Not Found' endhandle !line = '"$!attribute"' + ',"$!value"' + ',"$!type"' !lines.append(!line) enddo enddo -- Add Attributes to Array !file.writefile('write', !lines)
