Pixmap Image location has spaces
How do I load an image using pixmap, where the path of it's location has spaces ?
Thanks
  • Hello, not sure what your code looks like but I imagine that you are trying to define the pixmap location in the form definition (setup form / exit) instead of defining the pixmap location in the form constructor method. Defining Pixmap File path with spaces does not work in the form definition.
    To further illustrate what I am mentioning, here is an example from AVEVA TM-1881 PML Form Design manual where the pixmap location is defined in the form definition.
    setup form !!traExampleParagraphs
       !this.formTitle = |Paragraphs|
       para .para1 text |Normal paragraph gadget| width 25
       !t = |A coloured paragraph gadget|
       para .para2 at x0 ymax.para1 backg 157 text |$!t| width 25
       para .para3 at x0 ymax.para2 pixmap /c:\Temp\AVEVA_E3D_Graphic.png width 30 height 75
       para .para4 at x0 ymax.para3 + 0.5 text || wid 25 hei 2
    exit
    define method .traExampleParagraphs()
       -- Update the displayed text using CONSTRUCTOR method
       !this.para4.val = |Above was a PIXMAP, while this is
       split onto two lines|
    endmethod
    The pixmap location is defined in the line:
    Syntax in the form definition is somewhat very strict. File path with spaces will not work even if it is enclosed as a string. If we were to change the code above to a path with spaces, it will no longer work.
        para .para3 at x0 ymax.para2 pixmap '/c:\Temp\New folder\AVEVA_E3D_Graphic.png' width 30 height 75
    To avoid the syntax restriction, we can define the pixmap location in the form constructor method.
       -- para .para3 at x0 ymax.para2 pixmap /c:\Temp\AVEVA_E3D_Graphic.png width 30 height 75 Commented out
       para .para3 at x0 ymax.para2 pixmap width 30 height 75
    exit
       !this.para3.addPixmap('/c:\Temp\New folder\AVEVA_E3D_Graphic.png')
    endmethod
    The .addpixmap() method allows spaces in the file path. This .addpixmap() method is also available in other gadgets.
    In addition, based on what I have seen so far, the common practice of handling pixmaps is saving them together with your pmlfrm files in the PMLIB folder. With this you can use the !!pml.getPathName() method so you no longer have to specify the full path everytime.
    !this.para3.addPixmap(!!pml.getpathname('AVEVA_E3D_Graphic.png'))
  • I should have said here that I managed to get it working. I had to use the "addpixmap" and "pixmap" exactly how you showed above.
    What I tried orginally and didn't work for some reason
    exit
    What did work :
    exit
    endmethod
    Thanks for your help !
