Hi all
As per the title topic, what is the command to expunge user on admin module?
I tried to type: expunge SYSTEM but it's not correct.
Please advice to me above question.
Hi all
expunge itself is command. you can try $q to see the further arguments. don't forget to try show !!syntaxhelp
Hello Shivang...Thanks for this info. I can only see my log in when click EXPUNGE>USER Process in ADMIN....do you know how I can see all the users in a project?...I am using ADMIN 1.9
Hii Ulsa, I am not sure about your setup but generally, if you are free user, you can see all the users to expunge. But if you want to check the functionality available in forms, you can use q var !!fmsys.shownforms() .... it will give you form name, open the forms and check the functionality
