PDF / Export
I see in E3D via the menu you can create PDFs either via the plot or export command. It appears there is no difference in the outputted pdf , only the options to create the output. ie multiple sheets at once as singular files and also multiple sheets as one multi page single pdf.
I have written a program to output multi sheet outputs with the plot command and it works well, however I would like the option to be able to create a multi page single pdf file. It appears there are no options within the plot command. I looked at the export command within pml (LIEXEC) and it appears it does not support PDF, even though the menu version does.
Any tips for achieving this ?
Thanks
