Collecting the values of an Array of attribute Names
I know there is a way to collect all the attribute names of any given element into an array
!x1 = !!ce.attributes()
Is there a way other than looping through each attribute name to collect the value of each attribute ?
Thanks
  • please see below for a simple loop where values of each attribute is stored in !x2 variable
    !x2 = object array()
    do !strAttrib values !x1
    !varAttrib = $!strAttrib
    !x2.append(!varAttrib)
    !varAttrib.delete()
    --delete the !varAttrib variable to make way for the next type
    enddo
    but normally, i prefer ATTLIST as it will give all the attributes including UDA
    !x1 = !!ce.ATTLIST
    handle any
    -- I don't know about this as some of the result of atttlist is truncated and it will give syntax error (example GRADE attribute of GENSEC will be GRAD)
    !varAttrib = 'ERROR IN EXTRACTING ATTRIBUTE'
    endhandle
    !varAttrib.delete()
    enddo
  • Thanks for that. That is sort of what I have done
    I thought there might be a command similar to the one to get the attribute names !a = !item.attributes() for getting the values
    eg !b = !a.values() - doesn't exist
