Admin Module E3D and PDMS
  • Replies 10 replies
  • Subscribers 10 subscribers
  • Views 47 views
E3D and PDMS
Aaron Tan
Aaron Tan over 11 years ago
  • Aaron Tan
    Hi All,
    I was under the impression that E3D can work in conjuction with PDMS 12.1 but it is not backward compatible with previous versions of PDMS e.g. 12.0.
    Is this an incorrect impression?
  • Venkata Rao Peta
    It is Compatible with 12.1.
  • Aaron Tan
    deva,
    i was wondering whether its backwards compatible with previous versions of PDMS. 12.0 and below
  • Pedro Valadares
    Pedro Valadares over 11 years ago
    From the information I read Everything 3D is solely compatible with PDMS 12.1 (not previous version like 12.0).
  • Usman Shehu Isa
    Usman Shehu Isa over 9 years ago
    Is E3D backwards compatible with 12.1 sp 2?
  • Pedro Valadares
    Pedro Valadares over 9 years ago
    From what I read it is possible to use both E3D and 12.1.SP4 in the same project.
    This is not possible with 12.1.SP2.
  • Maxime BIOU
    Maxime BIOU over 9 years ago
    E3D uses 12.1 databases. You can work in a same project with PDMS 12.1.SP2, PDMS 12.1.SP4 and E3D. But it is of course recommended to work with a unique version.
    The PADD databases (DRAFT / DRAW) are the exception: once they are opened with E3D, they cannot be reopened with PDMS 12.1.
  • Admin
    Admin over 9 years ago
    Cause in E3D for draw Module had added the final designer where in PDMS the final designer is not added in draft module.
  • RAJENDHAR RAMENDLA
    RAJENDHAR RAMENDLA over 4 years ago
    Hi
    We have customized the PRIMARY & SECONDARY (SECIONS) Supports in PDMS 12.1 sp4. Can we  place and modify these support in E3D?.
    Or do we required to convert or upgrade. Could you please explain I this regard.
    Thanks
    Raj
  • Cary
    Cary over 4 years ago
    It is better to Convert it to GENSEC.
    As far as I know, SCTN cannot be modeled in E3D by default. Although SCTN is still available, you may need custom functions to use this in E3D environment or do it in command line.
