Admin Module (1,18) Filing Error 15
  • Replies 12 replies
  • Subscribers 11 subscribers
  • Views 102 views
Atish naresh parkar
Atish naresh parkar over 11 years ago
Top Replies
  • Atish naresh parkar
    Atish naresh parkar over 11 years ago +1
    The above issues has ben resolved Option1: moved the project from the Network drive to local and carried out the merge and it worked without any issue. Option2: Even after expunging users from…
    While Mergeing Database the below error message pops up
    (1,293) File may be in use from another Project as Foreign Database
    Messages in Command Line are as :
    Compacting DB DESSTRUC/STDDESTRU
    Size before Compact: 111328 pages 217.44Mbytes
    Size after Compact: 32715 pages 63.90Mbytes
    (1,18) Filing Error 15 - Cannot open /%STD000%/std12204_0001 database file
    after the above message I checked the Project Directory std000 there is an additional file generated as
    std12204_0001.cmpct
    I cant delete or cut the exisiting std12204_0001 file as its giving a message file in use by other application
    I tried Expunge all users, Expunge Claimlist and Data integrity Check for this particular Database.
    I confirmed this Db is not as a foreign Db i nany project.
    Is there any command to know whether a  Db is part of any other Project as a Foreign Db.
  • Venkata Rao Peta
    Deva Thanks for the reply
    This has already been checked
    Option2: Even after expunging users from the Admin module, Users are still locked on some of the databse file found by  Microsoft tool by IT administrator from the Server. Expunging them from Microsoft tool  from the network drive helped to resolve the problem
    Still not sure what could be the reason for users are not expunged fully from the database file and need a support of the Microsoft Tool.
    • Vote Up +1 Vote Down
  • PRASHANT PRAKASH UPARKAR
    PRASHANT PRAKASH UPARKAR over 11 years ago
    Sometimes a file gets locked. In such case you may need to take IT help to unlock the file.
  • Admin
    Admin over 11 years ago
    what do you mean by compacting MDBs? you can merge databases sessions
  • samoila laurentiu
    samoila laurentiu over 11 years ago
    Is there somebody who tried to make compacting with a pml function? Is this possible?
    What is your aim?
  • samoila laurentiu
    I would like to compact all mdb's from the project at a certain date and hour.
    For example I want to set Aveva to start compacting all mdb's o Saturday at 9 am.. Is it possible?
  • samoila laurentiu
    I mean merge database.
