Admin Module Deleting a project
  • Replies 6 replies
  • Subscribers 10 subscribers
  • Views 30 views
Deleting a project
Mojtaba Zare
Mojtaba Zare over 10 years ago
    You need to edit and clean C:\AVEVA\Plant\PDMS12.1.SP4\PDMS\ProjectInfo.xml
  • Mojtaba Zare
    Hi dear friends.
    I have just tried to open an existing project for the first time. I used project creation wizard and created a project with the same name and code. Once I did it I was curious to do it again! So I deleted the project folder not thinking about what would happen consequently. I did this procedure once again but the creation wizard gave the message that "Project already exists". I even edited the evars batch file and deleted the last line concerning with the new project. Still I have this problem and I can see the project in the "existing projects" tab of creation wizard.
    Where else does the project exist? what should be done to delete a project completely and create another project with the same code?
  • Mojtaba Zare
    Thank you very much [COLOR=#3E3E3E]Corrado. It's done.[/COLOR]
  • chiragparmar
    chiragparmar over 4 years ago
    Hello,
    In e3d where we get this file?
    Thanks,
  • Parag S Newe
    Parag S Newe over 4 years ago
    you will find this file below
    "C:\Users\Public\Documents\AVEVA\Projects\E3D2.1"
    folder
    HTH
  • chiragparmar
    found it.
    thanks paragnewe
