• Hi
    I have set up a system wherer the users can identify who has what AVEVA license checked out. Primarily for the MEI module as we only have one license.
    I have a bat file that extracts usage data from the RMS process and copies it to a network location as a CSV file.
    I create this using the
    "C:\AVEVA\AVEVA Licensing System\RMS\lsusage.exe"   -l  "C:\AVEVA\AVEVA Licensing System\RMS\usagelog.log   \\networklocation\am.txt
    unfortunately this is anonymised and requires an additional file C:\AVEVA\AVEVA Licensing System\RMS\usagelog.xml  to match useage records with user names. I cant for the life of me how this was created and is now out of date.
    Does anyone know if there is a command line option for the "AvevaDeAnonymizer Tool.exe" which would generate a report with actual user names in it or if there is another way to generate a usage file with clear text usernames.
    thanks
    Wayne
  • after some reading the WlmAdmin tool provides the functionality I require.
    Just needed to set the preferences to the AVEVA default server port 4545 and add our server as a defined server.
  • Hi , Wayne
    would you please explain more. I have same problem with Lsusage. I am going to prepare a report of usage.
