Admin Module DICE - Interpreting results
  • Replies 9 replies
  • Subscribers 11 subscribers
  • Views 154 views
Laurence Neo
Laurence Neo over 6 years ago
  • Laurence Neo
    I got some results from DICE check which I cannot understanding, any experts out there who knows how and why?
    1. Design database
    e.g. 1 -  Element =67293908/69939 Warning- Attribute RREF contains invalid ref =67367636/1185
    Element =67293908/69939 is a SCTN but there is no Attribute RREF under it so how can there be an invalid ref.
    e.g. 2 - Warning in level 1 UUIDAR table, session no. 33829, page no. 164074 - first key on lower level page no. 160719 (extract 1) may be incorrect.
    No clue what this message means and how to resolve it.
    Even with these messages the database has no structural error.
    Have you tried running DICE with "patch" option switched on?
  • Venkata Rao Peta
    For e.g.2 you should reconfigure database with same ref as it is a fatal error.
    For e.g.1 iam not sure longback i faced this type of issue, could you please check this post.
    RE: Clean up Orphan Status Links
    Better Try DICE with Patch on before reconfigure any database
  • Laurence Neo
    Thanks guys for the feedback. I've tried DICE with patch "ON" option and but errors are still there. Since the database has no structural error I did not want to reconfigure the database.
  • RAVI KUMAR
    RAVI KUMAR over 6 years ago
    These are only warnings not FATAL ERRORS.
    • Vote Up -1 Vote Down
  • Venkata Rao Peta
    Fix References for elements which are having unknown ref..
  • Josef Geltl
    Josef Geltl over 6 years ago
    [QUOTE=yuki;110260]I got some results from DICE check which I cannot understanding, any experts out there who knows how and why?
    1. Design database
    I think the invalid ref is at the CataDB Element.
    Check this Catalouge element for the missing REF.
    Regards
  • Arif Kazaro
    Arif Kazaro over 1 year ago in reply to Laurence Neo
    Hi,
    happen to me on SUPPORT MDS e3d.3.1.7
    my finding was, the template frame used for creating the support (eg Frame T Pos) , has been changed (delete old stru, create new stru).
    The Element = xxx/xx is refering to gensec  under support mds.
    need to renew/reselect those support (that using old template), with the new template.
  • Arif Kazaro
    Arif Kazaro over 1 year ago in reply to Arif Kazaro
    plus, in my country, people still using PDMS "macro" for generating structural detail modelling,
    For example, they create JLDATU/PLDATU/ENDATU and insert Fixing, and TMPL (manual command window) to model the detail (Stiffener, gusset, negative box for shaping the end of gensec to be sloted to another gensec)
    Hence most of the gensec reported to be invalid ref comes from the children of the gensec itself due to not using e3d correct procedure.
