We need to combine two different E3D projects from 2 subcontractors. Each project copied the AVEVA supplied DBs for the multidiscipline support purpose. These AVEVA supplied DB copies were modified according to each subcontractor's preference so eg. DB number 7007 from subcon A is not anymore same with DB number 7007 from subcon B. One of these copies should be reconfigured to a different. Here's what we did:
1. Set protection to false of eg. DB number 7007
2. performed merge and integrity check patch on
3. reconfigured 7007 to 11000
4. DB number 21019 is referencing 7007 previously, tried integrity check 21019 with external reference checked .
5. DICE report shows few objects still linking to 7007 and majority to 21019 . Note that DB number 7007 is not anymore existing and used.
for some AVEVA supplied DBs that we reconfigured, there are no issues after reconfiguration to new DB number.
Error message in the DICE log after reconfiguration from 7xxx to 11xxx
Error getting session no. 55827 from database
Modifying the DB number is a must otherwise I can't be able to include the DB with conflicting DB numbers, especially in a global environment. It's not the best practice but we have no choice but to find solution for this.
Has anyone experienced this?
Thank you.
