• Hi Guys,
    I have a really disturbing issue for me. I'll try to explain my problem.
    First of all I wanted to make a Bolt Spec. I have created bolt catalogue, ( Gtype:BOLT) created one parameter as per "nominal bore", starting from 10 to 52.  (I'm not mentioning the bolt tables which I have created earlier) After that, I have created a Bolt Spec, (Spec Type :Bolting) choosed Heading to Bolt, then tried to add new items to that spec. Choosed my bolt catalogue I have created earlier, when I click to apply, only I got two bolts whose nominal bores are 10 and 20. I assume that this is because of size range.( Cause when I change nominal bore values according to this size range values, PDMS shows all of them). So what can I do to add my bolts  ? I need urgent recommendations..
    thanks for your help..
    safa
  • Please do not use Catview for creating Bolt Spec. And no need to create Bolt Scom for all sizes, only one Dummy (no parameter) Scom is enough for all bolts.
  • thanks for your reply Mr. P.BASKER , would you please clarify creating a botl spec with a dummy scom.
  • Ya well,
    You can use the SEARCH facility of this forum; you will find lot more about Bolts.
