Bolting How Can I Know Bolt Length??
  • Replies 6 replies
  • Subscribers 2 subscribers
  • Views 32 views
hanwook Park
hanwook Park over 16 years ago
  • hanwook Park
    NOW, I'm using new bolt method. but I want check bolt length in design module. I have seen but I foggot the command. so, do you know the command find bolt lengs? If you know tell me.
    thanks~:mouth_closed:
  • øystein vindenes
    øystein vindenes over 16 years ago
    almost as simple if you just do a quic iso, the bolt len will then come in the mto.
  • hanwook Park
    thanks I know but I want another methods sometime i need it
  • P.Basker
    P.Basker over 16 years ago
    why don't you use SEARCH facility of this Forum?
  • john pitchers
    john pitchers over 16 years ago
    go here
    http://www.pdmsworld.com/forum/showpost.php?p=5651&postcount=4
  • Poonam Kulkarni
    Poonam Kulkarni over 16 years ago
    select flange and try following in command window
    q  P1 Bolt 1 Blen
    this will give you bolt len
    q P1 Bolt 1 Noff
    this will give you nos of bolts
