Bolting How to query LENGTH of SBOL
  • Replies 7 replies
  • Subscribers 2 subscribers
  • Views 23 views
Adisorn Vidhayavrapat
Adisorn Vidhayavrapat over 15 years ago
  • Adisorn Vidhayavrapat
    Hi,
    Has anyone know how to query LENGTH of SBOL, in attribute it has been had but I dont know why it can not query?? it said incomplete command line :mumbles:
    I need this query to extract the report your sharing idea is very helpful
    [COLOR="Blue"]Attributes
    Name /EA2,BE,400
    Type SBOL
    Lock false
    Owner /30189_BOLT_LIST
    Nstdblength /BS-M16
    Bdiameter ( 16 mm )
    Length 145mm
    Noff 8
    Xtralength 0mm
    Bitems unset
    Bitlength unset[/COLOR]
  • ram shankar prasad
    ram shankar prasad over 15 years ago
    apply some programming thought and ans is not far away...
    here it goes...
    q  ( attribute length )
    Ram
    I have tried to find out this answer for a couple day!! (it show me that I probably have to learn more in Programming)
    Thanks you so much Ram
    Adisorn
  • Admin
    Admin over 15 years ago
    [QUOTE=sanjay012344;32108]Hi
    i have need three nuts for 16" & above flange size and two nuts for below 16" flange size. in this case how do i consider extra length of nut?
    Under Xtralength 0mm
    Bitems nut (for extra nut)
    Bitlength 35 mm (nut height)
    But this 35 mm is not add when i generate isometric........
    plz help me
    What has this got to do with 'how to query LENGTH of SBOL'
    Start another thread.........
  • sanjay kumar saha
    sanjay kumar saha over 15 years ago
    Hi
    plz help me
  • amir jalaludin
    amir jalaludin over 15 years ago
    hi guys, im facing the same probem.
    for me , i try :
    quantity : Q NOFF OF BLTREF OF SPREF
    diameter : Q BDIAMETER OF BLTREF OF SPREF
    bolt reference : Q BLTREF OF SPREF
    so how about length?
    i try Q LENGTH OF BLTREF OF SPREF but it said it wont work
  • amir jalaludin
    Alhamdullilah,
    I successfully decipher what ramshankar7 means on his post above!!
    I managed to get the answer myself!
    Thanks u all esp. Ram.
    From land of thousand smile, Malaysia
    Stay fabulous!
    aJ
    Pasir Gudang, Johor. :):whoohoo:
