I am looking to change out a load of bolts from flanged connections which have already been placed within design. The Bselector in the flange attribute is unset, I wish to change this to a value to enable a second bolt option to appear. To do this I think I need to generate a report at site level which will allow me to change this attribute. There is several sites with hunderds of pipes where I want to change the bolts out.Can anyone help with a report template that will allow me to output this info and edit to suit before running it back in.
Yes this can be done too.
And also the if you know how to play around using lists then
1. Select flanges using the criterion given above.
2. In the command line type ALP LOG /C:\runfile.txt
3. then in the list box command line type in q ref bsel. Run it
4. ALP LOG END in the main command line
5. Your list with the necessary formatting (as said in the above post by pdmselder)
is ready
6. Replace the BSEL using PFE32 or Excel
Thanks for all the help, I managed a project wide change of BSEL for flanges valves Nozzles etc and gasket option changes after a mornings editing. I am very grateful thankyou
