regarding bltlength of same spec and same dia of blt and different number of bolts
  • Nothing required in Paragon.
    Did you set the BLTREF for XXX to the new SBOL in the Bolt spec
    $S-
    $(  BORE UNITS MM    $)
    $(  DISTANCE UNITS MM    $)
    NEW SPECIFICATION /BPWMSCC
    VERSION 1151
    MATREF =0
    FLUREF =0
    RATING 0.000
    LINETYPE NULL
    BSPEC =0
    TEXT 'BOLTING'
    HEADING
    TYPE  NAME          BDIA   BTYP  BSEL  SHOP  CATREF  DETAIL                                        MATXT                     CMPREF  BLTREF
    DEFAULTS
    -     -             -      BOLT  DEF   =
    BOLT  */BBWMSCCD      12.70  BOLT  DEF   FALS  /BOLT   /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2  /ASTM.A320.GrL7/A194.Gr4  =0      /BBWMSCCD
    BOLT  */BBWMSCCD:X  12.70  BOLT  XXX   FALS  /BOLT   /STUDBOLT.+.2.HVY.HEX.NUTS.ASME.B1.1/B18.2.2  /ASTM.A320.GrL7/A194.Gr4  =0      /BBWMXCCD
    I use this method to switch bolts for Insulation Gaskets so there is no reason I can think of that it should not work in your situation
