Please Help with New Bolting problem -Valve with caps on one end and machine on other
  • I have a valve with cap screws on one end and machine bolts on the other.  I can't get both sets to show up on the iso bom.  I have bolt arrays for both types and reference them in the blrfarray for the valve.  Upstream flange has Bsel set to CAP (for machine bolt with nut) and downstream flange has Bsel set to TAP (for cap screw)  When I set the Bsel on the valve to CAP, only upstream bolts show in the iso bom.  When I set the valve Bsel to TAP, only the downstream bolts show on the bom.   If I leave the Bsel unset, neither bolts nor cap screws appear in the bom.   I am using one bolt spec with the BTYP set to Bolt and using BSEL to differentiate between the different kinds of bolts required in the piping spec ( ANSI studs, DIN cap screws and DIN machine bolts ).  How can I get bolts and caps with their different Dtxt and Mtxt to show up on the iso bom?
    Thanks in advance...
  • Assuming Machine Bolts are the default set BSEL for these to DEF
    Create new entry in boltspec for the Capscrew with BTYP CAP and BSEL CAP
    Create a Boltset with BTYP set to CAP
    Create a new flange SCOM with BLRF set to the new Boltset and add it to the spec (use same speco name with suffix :CAP and an STYP to distinguish it from the norm.)
    Use the new flange at the Capscrew end of the joint. No need to set BSEL on any of the components.
    The "normal end" will use the default bolt. The new flange at the "Capscrew end" will force the use of "CAP" bolt
