wel i came across a condition where the bolt material has to be changed depending upon the selection.
for ex: when a simple connection like Flange gasket flange will have "x" material bolt
& Flange gasket valve gasket flange will have "y" material bolt.
i hve seen a similar example in manual for shop if it is true the user has to select the flange whose shop is true..... instead of tht is there anyway where it can be achieved.
looking for the solution...... the bolting method is OLD.....
How are u doing..... merry christmas...and a happy new year.......
wel i knw u r the master for cats & spec and have query......need ur help.....
i hve defined the Relief valves as desparams and the second size of the valve is also defined as desparam where the second size will be defined by a user....
the issue is assigning the bolref.....the mbolt of the valv should take the connect falge reference is there a method to achieve it......
the main advantage here if the second size is a user definable then i will not have any request for the RV from the user for every project......I just want to make the speciality components a standard.....
please let me know how to proceed......if i want to keep the second size of valve as desparam.....
