Hi guys,
I am trying to pull out a report for pipig and fittings and nuts and bolts.I gives me the pipig and fittings thru Utilites>Reports>run... but it does not include any bolts and uts in there.
My question is How to fix the report "standard PDMS reports for MTO" to give me the uts and bolts as well.
bolts and nuts are generated when you use isodraft... i saw in this forum some macros to extract bolt mto.. try to be patient to use the search engine..:)
it is simple go to isodraft
than goto menu isometric-standard
a box will appear select detail list
add allpipe whose bolt report u want to generate
after that in place of produce isometric use bolt report
it will ask you bolt file name be bolt say yes than i will ask you the bolt coordinate if you say yes than it will come iso wise if you say no it come in bulk report
the report file u will find in c:\window\bolt
open that file with open with txt file
[QUOTE=HENDIBAHRAM;77455]bolt report give us report of the bolts and sum (same diameter and same length of the bolt with together but not consider same material- for example if the bolts have a same lenght and same diameter but have a different material(B7,2H) bolt report sum the number of the bolts with one of the material and this is wrong.
we have bolts 1/2" (dia.) /length 65 (mm) /no.4 /material 2H
and 1/2" (dia.) /length 65 (mm) /no.4 /material L7 result of the bolt report is 1/2" (dia.) /length 65 (mm) /no.8 /material 2H and this is wrong. please try this subject and advise me.
Without trying to replicate our problem because it is not possible not having your data, I would have say that your bolting spec done wrong if it gives wrong material.
About number of bolts... Are you sure you don't have two flange assembly each of 4 bolts?
I think that bolt report does not consider the material for sum- only diameter and length have been consider for sum- and this is wrong
please try this for example:
bolt 1/2" (dia.) /length 65 (mm) /no.4 /material 2H
with bolt 1/2" (dia.) /length 65 (mm) /no.4 /material L7
result of bolt report is :
it mean that material does not consider for sum.please check it and advise me
