For the new project spec to be created, I have replicated old project structure.
We were used old bolting method earlier, now we need to change new method as per client requset,
If I change bolt method form old to new in spec and do necessary settings as per new bolt method required ????
There´s no need of change of settings, the only thing that you must do is to make your specs to suit the new bolt method, that sucks!!
Good luck, you´ll need it.
:D
We were used old bolting method earlier, now we need to change new method as per client requset, If I change bolt method form old to new in spec and do necessary settings as per new bolt method required ????
You will have a lot of work: All SCOMs which require bolted joints have to get the BLRF attribute set.
Have a look into the Isodraft manual and try to understand the logic. Not easy!
But once you are acquainted with New Bolting you never want to return to the old method!
