-- You Current Element Either Site or Zone -- The program will collect all pipes and will for the Site or Zone var !COLL COLLECT ALL PIPE FOR CE var !EVAL EVALUATE (NAME) FOR ALL FROM !COLL do !I VALUES !EVAL ADD $!I BOLTREPORT $!I handle ANY $P $!!error.text endhandle enddo -- Following are Isometric options. -- Change As per your requirement BOLTFILE /C:\TEMP\LINE-WISE-BOLT-REPORT.TXT MESS /C:\TEMP\mess over -- Change As per your project Setting Itemcode from SPREF -- Change As per your project Setting MaterialList Code 8 -- Change As per your project Setting Itemcode Length SHORT -- Change As per your project Setting Delimiter COLON -- Change As per your project Setting Bolting length description ON -- Change As per your project Setting Bolting Units METIMP
