I am building butterfly valves. Some valves require lengths that are to be exact per manufacturer. The cap screws come out on the Iso Bill Of Material.
I was going to adjust per the XTRA in the SBOL, or adjust FTHK in the BLTP.
I can make the Cap screw longer, but when I enter negative values, The Cap screw never adjusts to be less than 2"
Where can I enter data to make a cap screw adjust to the length that I require?
Make sure that the lengths you require less than 2" are included in the DTAB Blengths.
If the Blengths start at 2" then that is the minimum length PDMS can use.
[QUOTE=pitch;75326]Make sure that the lengths you require less than 2" are included in the DTAB Blengths.
I tried this and it worked. Thanks so much for responding.
