I started doing new bolting method.
In paragon, created SECTION, BTSE, BLTP. AND BLTA , LTAB, DTAB & BLIS, SBOL
And
I built new bolt spec and successfully created.
I change the Pipe spec attributes
1. Bolting method 'NEW'
2. Bspec /K.BOLT.150#
Then Design Module I created a pipe, and Try to extract Isometric, isometric is generating but there is no Bolt details
My Bolt spec is as below mentioned.
Help me please.
[COLOR=#0000cd]$S-
$( BORE UNITS MM $)
$( DISTANCE UNITS MM $)
This seems to be a mix between old and new bolting method.
Stext of Text is wrong.
And you miss Catref, Detail and Matxt.
Bltref is pointing to an "old" Sbol element.
I would suggest to search on this forum.
New bolting method has been discussed many times already.
Or, even better, I would suggest you to attend a proper Catalogues & Specification Training Course with Aveva personnell....
While Spec Creation BLTREF is Mandatory and Important. Bolt reference is a SBOL reference.
SBOL is having DTAB reference. BTSE is referred with Flange Blrfarray (SCOM)
Bolt description & Material details are described with SDTE & SMTE, same thing is provide while creating bolt spec.
I followed the same
