The way the selection works is explained in the following rules:
-If the BTYP for both sides of a joint is set to BOLT, the default bolt of the given diameter is used.
-If the BTYP for one side of the joint is set to BOLT and the other side is set to anything other than BOLT, the type of bolt specified by that BTYP will be used.
For example, a bolted through flange may have its BTYP set to BOLT, and the mating flange may require cap screws and have its BTYP set to CAP. In this case, the cap screw overrides the default type, and the selected BTYP will be CAP.
-If both BTYPs are the same and are not set to BOLT, the bolt with that BTYP is selected.
-If the BTYPs are not equal and are also not set to BOLT, the BTYP from the start of the bolt is selected.
