I am using Old Bolting method, and I have assigned BWEI attribute based on Blen of DTAB.
Now I want to take a report for Bolt weights for any particular Flange.
How to do it?
Hello, can you please tell me what is BWEI? I've try to find some information about this attribute, but I didn't find anything. I need to insert on the isometric also the bolt weight, but it's not possible only defining the weight on the CMPT of the bolts.
Hello Daniela.
I see you are from Italy.
You can contact Aveva Italy at [email]supportplant.italy@aveva.com[/email]
We will be more than happy to help you.
Ciao
Corrado
Thank you very much Corrado for your quick answer.
Reading some information about this attribute I understand that is a new attribute used for 12.1 PDMS version, so in my case in this moment I'm not able to used it because my version is 12.0 SP6.
Is there a possibility to get the bweight when using BOLTREPORT Command. Is there any options to change setting on what attributes to collected when using BOLTREPORT command. As of now, I am using PDMS 12.1 and utilizing the new attribute bolt weight.
