Bolting Rpro flth
  • Replies 8 replies
  • Subscribers 2 subscribers
  • Views 35 views
Rpro flth
Aaron Tan
Aaron Tan over 10 years ago
  • Aaron Tan
    Hi All,
    Could someone please explain to me RPRO FLTH?
    The Aveva supplied catalogue boltsets use RPRO FLTH for the flange thickness but when I tried using that for my custom CATE Isodraft doesn't seem to find something.
    I had to put the parameter at which the flange thickness resides.
    I was talking to a guy at Aveva that by default RPROs are not accessible to the DTSE. However he didn't have a chance to explain any further.
    Please help.
    Thanks
  • Aaron Tan
    Alright so I read that this is under the Data references. However why do you need to create a new data reference with key to set FLTH instead of just changing the key of the Parameter which contains the flange thickness?
  • Vineet Bhardwaj
    Vineet Bhardwaj over 10 years ago
    To maintain consistency......parameter key changes with the sequence number of parameter
  • Aaron Tan
    Alright cool thanks
    But then although you are maintaining consistency aren't we doubling up on data? Would it mess up the CATE if you change the key for a parameter?
  • Vineet Bhardwaj
    No it wont just read datasets from manual .
  • john pitchers
    john pitchers over 10 years ago
    [FONT=Arial][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][FONT=Arial][SIZE=4][FONT=Arial][SIZE=4][SIZE=1]Conventions for Catalogues and Specifications
    [LEFT]
    [/SIZE][/FONT][/SIZE][/FONT]The following Datakeys are reserved for use by the application and have the special[/LEFT]meaning shown:
    [/SIZE][/FONT][/SIZE][/FONT]FLTH Flange thickness of attached steelwork
  • Usman Shehu Isa
    Usman Shehu Isa over 9 years ago
    Hi,
    Can any one kindly clarify "RPRO"? What does it stand for? What does RPRO XOFF or RPRO ZOFF control? Thanks.
  • Venkata Rao Peta
    Venkata Rao Peta over 9 years ago
    RPRO Catalogue dataset property.
    xoff is x offset HORIZONTAL Offset
