Bolting No bolts for a valve
  • Replies 10 replies
  • Subscribers 2 subscribers
  • Views 24 views
sanjyot
sanjyot over 10 years ago
  • sanjyot
    Hi all,
    I have modelled a wafer type valve directly between two nozzles. In isometric, I am not getting any bolt data...
    Why it is happening ?
  • Vineet Bhardwaj
    Vineet Bhardwaj over 10 years ago
    You using new bolting method ?
    Check the command while iso extraction adn see if any ino there.
  • sanjyot
    i am suing old bolting method
  • sanjyot
    OOps..I am using** old bolting method
  • Vineet Bhardwaj
    check all bltref...and also check command line while iso extraction is there any message regarding bolting ?
    Orlando de Oliveira Amaral dos Santos over 10 years ago
    I'm having a similar problem, this is the message I'm getting in the command window:
    33:194) Starting to detail PIPE /SP057-LIT-FLANGECONN
    (61:390) Using OLD bolting method
    (33:231) Cannot find BOLT SPCOM with BLTREF SBOLT /ISBBL-SP057 for PCOMPONENT 1 of BRANCH /SP057-LIT-FLANGECONN/B1
    (33:235) Warning: Material list has short itemcodes from more than one pipe spec
  • sanjyot
    all bltrefs are there...then also this issue is coming..plz guide
  • Vineet Bhardwaj
    Kinsly share your command line messages.
  • Vineet Bhardwaj
    [QUOTE=orlandoamaral;92083]I'm having a similar problem, this is the message I'm getting in the command window:
    Inside you pipe specification you need to have BOLT SPCOs.
    Check if they are there and if BLTREF attribute is set.
    One of them should point to /ISBBL-SP057
    Hi vineet,
    You opened my eyes man, the hole time the problem was in front of my and I couldn't see, the thing is this PCOM we're are using, is in a different spec, that didn't have the bolt on it, was just a matter of add the bolt to it and problem solved!!
    Śukriyā!
