I have read through a lot of the threads on this forum on Bolt sets and I just want to double check:
BDIA, BTHK and BTYP are string attributes so you can put an expression e.g. RPRO FLTH
However NBOL is a real attribute so if you were to try to put an expression an error message appears
Is there a way to assign an expression to NBOL?
It just seems silly to me that you could possibly use datasets or parameters to set the BLRF array attributes and only require one BTSE for all sizes.
