Is it possible to exclude a bolt from the material list but keep still include any extra items e.g. nuts & washers?
I am tying into a nozzle that has existing studs that I am utilising so all I need on the iso is 2 nuts and 1 washer on the flange side.
I have almost the same task but vise versa, users ask to exclude wash and nuts for one project.
The easiest way will be to create bolt spec(BS) with wash and nuts only and to refer to this BS from pipe specS.
HTH
So for the Bolt type of the CATE's boltset is it alright to have it set to BOLT?
And then when you setup the bolting table do you put extra items as washer/nuts? or do you not have a standard bolt reference?
And then if when it comes to the final iso output how do suppress the length? I know there's a switch in the options file for bolt lengths but if you change it then all the other normal bolts will not have a length in the description
I can't really create a standalone bolt spec with washers/nuts and reference it to the pipe spec because i only need one "boltless" connection and all the other flanges require bolts
