Hi experts,
I am facing the problem with bolt length with spec break. When there is spec break with flanged components ,the bolt length calculated is taking 5 mm more compared to normal bolt length.
my dtab values are with interval of 5 mm.
hi
We are using old bolting method.
DTAB intervals are 60,65,70,.....................................1000
for example when we are using SAME SPECIFIACATION BOLT LENGTH IS 75
When we are using flanged connection with one of the flanged connection from other spec(rating and material is same in both spec) it shows bolt length as 80mm
No trouble at all!
Is just that next time I suggest you to give as many info as possible in the first post.....expecially talking about bolts! :-) :-) :-)
Do you have any component in between? (i.e. wafer components - spectacle blind - orifice place etc etc)?
Have you run Data Consistency for both pipes?
