Bolting bolt bore unit
  • Replies 14 replies
  • Subscribers 2 subscribers
  • Views 190 views
bolt bore unit
tony liu
tony liu over 7 years ago
  • tony liu
    Hi, as per the ASME B16.5, under the metric unit system, the bolt bore size is given in imperial, in my project the unit system is metric, how should I get the imperial unit for the bolt bore size?
    thanks a lot in advance;
  • Venkata Rao Peta
    Venkata Rao Peta over 7 years ago
    Need to convert into metric, as Projects Run either in metric or imperial.
  • Jens Klindt
    Jens Klindt over 7 years ago
  • tony liu
    Thank you very much, FromHH for your reply, I am trying to figure out if I could introduce the imperial bore of the bolt into my DXTR's STEXT attribute, if could what expression should I use?
    any further smart ides?
  • Mohd Fadzli
    Mohd Fadzli over 5 years ago
    Hi All,
    My project use Bolting  Units  METRIC in option file.
    The bore diameter(BDIA) size in BOM appear as 16 MM.Our project team require the bore to be appear as M16.
    Can isodraft provided output as requested by project team?
    Thanks
  • Venkata Rao Peta
    If item code you provide as MBOLT-M16, They can't manage?
    Bore will appear as Real value in N.S.(MM) Column.
    Iam also eager to know if there is some solution for this.
  • Tejas Desai
    Tejas Desai over 5 years ago
    did u use  following code????
    Bolting Units [COLOR=#333333][COLOR=#333333]METRIC PREFIXBOREUNITS[/COLOR][/COLOR]
    [COLOR=#333333][COLOR=#333333][FONT=Verdana]ATEXT 207 'M'
    [/FONT][/COLOR][/COLOR]
  • Mohd Fadzli
  • Mohd Fadzli
  • Amrut Suthar
    Amrut Suthar over 4 years ago
