Design Module 3d text permanent color
  • Replies 10 replies
  • Subscribers 8 subscribers
  • Views 60 views
Nisar Ahmed Dingankar
Nisar Ahmed Dingankar over 5 years ago
  • Nisar Ahmed Dingankar
    Hi,
    I have used Plantcon 3D Text Macro to create 3D Text in my 3D model. How to give permanent color to this 3D Text.
    Appreciate your help.
    Hi,
    Please can anyone help.
  • me_hungry
    me_hungry over 5 years ago
    To set permanent color, you have to use Autocolor Rules.
    Search on youtube for video manuals or read help..
    You can set some attribute for SITE/ZONE.. where you created letters and
    use expression in Color Rules to distinct them from others.
    Hi,
    Thanks me_hungry , I did as per your instruction, but still the color is not changing. below is the editing i did.
    My Zone name is "3DTEXT"
    I modified "des-element-rules.pmldat" as shown below :-
    !rule             = object RULE()
    !rule.name        = |3DTEXT ZONES|
    !rule.rule        = |Name of Zone eq '3DTEXT'|
    !rule.types       = |ZONE|
    !rule.description = |Rule for 3DTEXT ZONES|
    !!tmpRuleArray.append(!rule)
    I modified "des-col.pmldat" as shown below :-
    !gphAutoColourRul = |3DTEXT ZONES|
    !gphAutoColTnslVal = 0
    !gphAutoColEdgeOn = TRUE
    !gphAutoColourCol = object COLOUR(|RED|)
    !gphAutoColour    = object GPHAUTOCOLOUR(!gphAutoColourRul, !gphAutoColourCol, !gphAutoColTnslVal, !gphAutoColEdgeOn)
    !tempArray[47] = !gphAutoColour
    Can you please tell me where I am wrong.
    Appreciate your Help.
  • adak
    adak over 5 years ago
    here is an example of my syntax for des-col.pmldat :
    !gphAutoColourRul = |Road Access way|
    !gphAutoColEdgeOn = FALSE
    !gphAutoColourExp = |185|
    !gphAutoColour    = object GPHAUTOCOLOUR(!gphAutoColourRul, !gphAutoColourExp, !gphAutoColTnslVal, !gphAutoColEdgeOn)
    !tempArray[1] = !gphAutoColour
    may be it help
    is the editing in File : des-element-rules.pmldat OK
  • adak
    for me, your des-element-rules seems to be ok.
    take care with [COLOR=#333333]!tempArray[47] = !gphAutoColour --> number 47 should be unique
    hth
    [/COLOR]
    Adak tx for reply.
    Number 47 is unique,  but still I cant change the color.. , do I have to change anything else..
    Experts please give your inputs.
  • Josef Geltl
    Josef Geltl over 5 years ago
    HI!
    It is important to consider the position in your des-element-rules.pmldat file!
    Maybe a higher or lower entr overwrite your entry while processing the elementrules
    from top to bottom.
    If I?m right the 3D Text is made of STRUS or PANEL`s.
    look for other elementrules which handles STRUS or PANE`s
    Regards
  • Ian Stanbrook
    Ian Stanbrook 2 months ago in reply to Nisar Ahmed Dingankar
    NAMN of ZONE in rule
