Hello, I am facing these errors for importing SDNF file. How to work on it.
Thank you in advance for your help!
SDNF interface is supplied with macros that create necessary UDAS in Lexicon.
Okay, I will check on this. Thanks for clarifying.
Corrado is correct at the time of of operation , you will be asked to run a macro(so that necessary UDA's are created), have you done that..if the problem still prevails just let me know.
Okay Sir, Thank you so much for your explanation. Working on the same. Will let you know if problem doesn't solve. Looking forward to connect you!
