Field weld at Olet Run Pipe
Hi Gents,
Appologize if my discussion in incorrect module, but I am unable to find Spooler Module. Our worker wants to weld the olet to run pipe at site which means the field weld required at P1/P2 of olet.
How can I add the field weld in this case to break the spool from olet leg at P1/P2 olet.
As when added, field weld will split the pipe piece of run pipe that is incorrect. Thank you!
