I hope everyone is having a good day. I am looking for a way to maintain the entire hierarchy all the way back to site, even when only a few items within that hierarchy have been added to the array. I.E. the RVM should always be the name of the site, even if it only includes 2 zones.
I am using an Array called sites to build my RVM list. I had it creating the owner of the zones earlier day, but I was not able to get it to loop and export all the zones listed from the array. I hope this makes since. Can someone please help?
----------------------------------------------------------------------------------------------------------------------------------- $* !RVMEXPORTFOLDER = 'C:\AVEVA\RVM_OUTPUT\' - PATH FOR THE RVM/ATT OUTPUT ----------------------------------------------------------------------------------------------------------------------------------- --!RVMEXPORTFOLDER = ('/C:\AVEVA\RVM_OUTPUT\FP-21-0021_LP5\RVM-P\') !RVMEXPORTFOLDER = ('/C:\AVEVA\RVM_OUTPUT\') ----------------------------------------------------------------------------------------------------------------------------------- $* !RVMEXPORTFOLDER = 'C:\AVEVA\RVM_OUTPUT\' - PATH FOR THE RVM/ATT OUTPUT ----------------------------------------------------------------------------------------------------------------------------------- !RVMEXPORTFOLDER = ('/C:\AVEVA\RVM_OUTPUT\') ----------------------------------------------------------------------------------------------------------------------------------- $* ADD SITE NAME TO THE ARRAY - EXAMPLE "!SITES = !!COLLECTALLFOR(|SITE|,|MATCHW(NAME,'*01*')|,WORL)" $* COLLECTS ALL SITES FOR INCLUSION IN RVM GENERATION. UNCOMMENT ADDITIONAL ROWS AS NEEDED. ----------------------------------------------------------------------------------------------------------------------------------- !SITES = !!COLLECTALLFOR(|ZONE|,|MATCHW(NAME,'*ZONE-EQUIPMENT-AREA02-B01*')|,WORL) !SITES.APPENDARRAY(!!COLLECTALLFOR(|ZONE|,|MATCHW(NAME,'*ZONE-EQUIPMENT-AREA02-B02*')|,WORL)) --!SITES.APPENDARRAY(!!COLLECTALLFOR(|ZONE|,|MATCHW(NAME,'*ZONE-EQUIPMENT-AREA02-B02*')|,WORL)) --Q VAR !SITES $* INITIALISE VARIABLES !ITEMS = !SITES ----------------------------------------------------------------------------------------------------------------------------------- $* REMOVE ATT FILE FROM THE ARRAY - EXAMPLE "SKIP IF (MATCHW ('$!ITEMS[$!K].NAME','*PIPING*'))" *.* WILL RUN ALL ATT FILES ----------------------------------------------------------------------------------------------------------------------------------- !RESULT = ARRAY() DO !K INDICES !ITEMS SKIP IF (MATCHW ('$!ITEMS[$!K].NAME','*STEP*')) SKIP IF (MATCHW ('$!ITEMS[$!K].NAME','*.*')) SKIP IF (MATCHW ('$!ITEMS[$!K].NAME','*.*')) SKIP IF (MATCHW ('$!ITEMS[$!K].NAME','*.*')) SKIP IF (MATCHW ('$!ITEMS[$!K].NAME','*.*')) !RESULT.APPEND('$!ITEMS[$!K].NAME') -- Q VAR !RESULT ENDDO ----------------------------------------------------------------------------------------------------------------------------------- $* START THE RVM PROGRESS ----------------------------------------------------------------------------------------------------------------------------------- do !NAMERVM values !ITEMS var !COLL coll all for $!NAMERVM LABEL /ALL EXPORT AUTOCOLOUR RESET EXPORT AUTOCOLOUR ON -- EXPORT AUTOCOLOUR OFF -- EXPORT AUTOCOLOUR DISPLAYEXPORT ON EXPORT AUTOCOLOUR DISPLAYEXPORT OFF -- EXPORT REPR ON EXPORT REPR OFF -- REPRE INSU ON TRANSL 75 REPRE INSU OFF -- REPRE OBST ON TRANSL 75 REPRE OBST OFF REPRE TUBE ON -- REPRE TUBE OFF -- REPRE CENT OFF -- EXPORT IMPLIED TUBE SEPARATE EXPORT FILENOTE '' EXPORT HOLES ON EXPORT SYSTEM /EXPDRI.SO !type = !!ce.attribute( |TYPE| ) do !INDX indices !COLL -- skip if(TYPE of $!COLL[$!INDX] eq |TUBI|) if ( !type NEQ |SITE| ) then !namervm = NAME OF OWNER --!NAMEATTR = '/' & !namervm.after('/').REPLACE(|/|,|_|) EXPORT FILE $!RVMEXPORTFOLDER$!OWNER$N.RVM OVER EXPORT $!COLL[$!INDX] EXPORT FINISH else --SAVE THE NAME OF THE CE SITE --!NAMEOFCESITE = !!CE.NAME --EXPORT FILE $!RVMEXPORTFOLDER$!NAMEOFCESITE$N.RVM OVER --EXPORT $!NAMEOFCESITE --EXPORT FINISH endif -- Q VAR !Array ENDDO ENDDO -- Q VAR !ALLEXPORT Q VAR !COLL
