How to control default entity color
I would like to control and setup the coloring in our model. This would be a company wide coloring standard. So far i've seen the representation rule dialog box, on which I can create coloring rule. My issue with this is that the user have to load manually the .pmldat file. Is there a way to control the default coloring rule, without loading the .pmldat file? If so, what is the loading mechanism...? Thanks!
