Does any one know if it's possible to toggle holes on / off but on individual items rather than the entire drawlist ?
If not, this function should definitely be added. Spend a lot of wasted time waiting for the entire model to regen
Thanks
Thanks
Be on the item and type
REPRE HOLE ON
REM CE ADD CE
only the selected item will be toggled.
Hi. Thanks for that.
I see what you did here, however that was only part of the issue I have. The main issue being that when you turn holes on / off, it regenerates the entire model and is very slow. I want to be able to just turn specific items holes holes on / off
