Draft Module Nozzle orientation drawing
  • Replies 7 replies
  • Subscribers 5 subscribers
  • Views 51 views
Anders Bergenholm
Anders Bergenholm over 18 years ago
  • Anders Bergenholm
    Hi
    What is the best way of creating outline drawings for tanks and towers with nozzle orientation and heights, in a table on the drawing, is the best way to use ADP or do we need some PML work done?
    The same is for checking drawings for nozzles on equipment's so the are according to installation drawings.
    Can any one help/guide me in the best direction?
    Thanks
  • Christopher Vitte
    Christopher Vitte over 18 years ago
    use the adp for what you are doing, just be sure to match it's rules.
  • Marcel Prosch
    Marcel Prosch over 18 years ago
    What is ADP?
  • HowD
    HowD over 18 years ago
    What is ADP?
    http://www.pdmsworld.com/forum/showthread.php?t=1174
  • Marcel Prosch
    Thanks, we didn't discuss that on training.
  • Olli Ekberg
    Olli Ekberg over 8 years ago
    Is there any possibilities to get orientatiom to example to label without ADP? How the orientation comes from design to draft (draw)? I know that there is ORIA but when I checked it in model it shows negative values for 270deg.
    I'm asking this because I'm making drawings from equipments for customer comments and it would easier to get value from design then making dimensions for it
  • Martin
    Martin over 6 years ago
    var !ori p1 dir wrt/*
    !O = !ORI.PART(1,'')
    !R = !ORI.PART(2,'')
    !I = !ORI.PART(3,'')
    !N = |0|
    !E = |90|
    !S = |180|
    !W = |270|
    !F = |360|
    IF(|$!ORI| EQ |N|) THEN
    !ANG = ($!N)
    ELSEIF(|$!ORI| EQ |E|) THEN
    !ANG = ($!E)
    ELSEIF(|$!ORI| EQ |S|) THEN
    !ANG = ($!S)
    ELSEIF(|$!ORI| EQ |W|) THEN
    !ANG = ($!W)
    ELSEIF((|$!O| EQ |N|) AND (|$!I| EQ |E|)) THEN
    !ANG = (|$!R|)
    ELSEIF((|$!O| EQ |E|) AND (|$!I| EQ |S|)) THEN
    !ANG = ($!E + $!R)
    ELSEIF((|$!O| EQ |S|) AND (|$!I| EQ |W|)) THEN
    !ANG = ($!S + $!R)
    ELSEIF((|$!O| EQ |W|) AND (|$!I| EQ |N|)) THEN
    !ANG = ($!W + $!R)
    ELSEIF((|$!O| EQ |N|) AND (|$!I| EQ |W|)) THEN
    !ANG = ($!F - $!R)
    ELSEIF((|$!O| EQ |W|) AND (|$!I| EQ |S|)) THEN
    !ANG = ($!W - $!R)
    ELSEIF((|$!O| EQ |S|) AND (|$!I| EQ |E|)) THEN
    !ANG = ($!S - $!R)
    ELSEIF((|$!O| EQ |E|) AND (|$!I| EQ |N|)) THEN
    !ANG = ($!E - $!R)
    ELSE
    ENDIF
    IF (|$!ORI| EQ |U|) THEN
    !ANGLE = ||
    ELSEIF (|$!ORI| EQ |D|) THEN
    !ANGLE = ||
    ELSE
    !ANGLE = |Angle| + | | + |$!ANG|
    ENDIF
    $p $!ANGLE
