I created a new layer of (DIMLAY) dimension in draft admin specialy from defaults file .But every time I changed the definitions of the layer for example (colour or font or CHEI) the draft takes the default definition of the program.How can I make a new layer with my definitions?
In this dimension layer properties set by aveva, [COLOR=#ff0000]Q EVAR |PDMSUI| [/COLOR][COLOR=#000000]IF you type this in the command line it will give the path of the PDMSUI, If it points to the above path then your project is using the aveva dflts, so create a dimlay file in your PDMSUI Folder i think you have your customized PDMSUI Folder.[/COLOR][COLOR=#ff0000][/COLOR]
