• [QUOTE=prius311;27247]Hi everybody,
    I have some questions.
    1. In Draft module, what does "Slab" mean? How it create or modify? (My purpose is "create" or "modify" "one point" in pipe support for construction. It is origin point for construction )
    2. I have four sub-frame in the drawing. When export drawing to DXF, the drawing of one in four sub-frame changing? Why? How it repaired? (Dimension in output drawing is larger).
    Thanks,
    Slab means a predrawn symbol with or without text that you attach to any item in drawlist, it cannot be amended (only by the administrator)
    Glab is identical but you have full control of its contents
    Cannot answer question 2 without further investing draft
  • Hi everybody,
    Thanks,
  • 1. SLAB - symbolic label (label with symbols and text)
    You can use menu Create -> Label.
    2. Import drawings in dxf with dra-dxf-full template from menu "Utilities->DXF CE -> Configurable". It has check mark "scale factor".
  • can someone tell me how to change the origin point of a stru...???
    thanks
