Draft Module PLANTWAVE problem
  • Replies 6 replies
  • Subscribers 5 subscribers
  • Views 5 views
PLANTWAVE problem
Admin
Admin over 16 years ago
  • Admin
    Hi guys
    i have a problem with plantwave,
    i made the view in pdms and when i want to get it from plantwave(PW1) i see that there written ''MDB not found''. what should i do?
  • avwf_de_ding
    avwf_de_ding over 16 years ago
    contact plantwave is your best bet.
    It can be something simple like you forgot to check a certain box since plantwave used DARS to access PDMS info.
  • Masood Sobhani
    Masood Sobhani over 12 years ago
    I have same problem, and I didn't get what you mean about DARS, would you explain more about your point?
    DARS=Data Access RoutineS
    You can read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\Data Access Routines User Guide.pdf
    Sorry but I do not know Plantwave.
    Have you read the manual I have suggested?
    If you have problem, in there you can read:
    Aveva Solutions Ltd can provide consultancy services to assist customers in the preparation
    of applications programs. The experienced programmer, however, will find DARs no more
    difficult to use than other well-written library packages.
    HTH
  • Masood Sobhani
    Thanks Corrado, but in plantwave software, what should I do to make the software access to PDMS using Dars?!
