basically i am talking about they piping GA (plan)
is it possible to show pipe hidding one below they other showing a pipe hiden below clearly in plan view itself, showing they above pipe cut, like what we do in autocad while preparing piping plan
You can if its for say a one or two off!
A lot of messing around but basically you add a second view with just the pipe you want cut, then create a box and change the box lpen to 254 (not sure if that is the correct number as I haven't used it for a while) this will make everything in the box appear blank.
As I say a lot of messing but it gets the job done for presentation.
For representation in draft, create a slab library symbol depicting a break in the pipe. Position over the pipe that was created as an element in design. This method is for simple views, otherwise, create a vsect and show a partial view at each elevation.
