One problem always bother us is the picture files of some sheets are not found or in wrong version number. I can use a macro to find out all the missed picture files, but can someone tell what is the reason to cause the picture file disappeared.
If the version number of a picture file is wrong, is there a way to find it out before I print or export it. Also, what is the reason to cause this?
Please see example below. pictue file /%XXXPIC%/08/M17160-12968-10000-112 has the wrong version number, after UPDATE ALL and SAVEWORK, the picture file name becomes /%XXXPIC%/08/M17160-12968-10000-113. I check the folder, /%XXXPIC%/08/M17160-12968-10000-112 is removed.
SHEET /XXX-300-CS-2386-0541001-001: Picture file has the wrong version number.
Updating annotation graphics for SHEET /XXX-300-CS-2386-0541001-001
[QUOTE=art125;44445]I know somebody in this Forum can help:
UPDATE ALL
SAVEORK
SAVEWORK
Q DRFILE
DrFileName /%MXXXPIC%/08/M17160-12968-10000-113
Another problem related to picture file happened to me: in one recently finished projects, we plot about 800 sheets to pdf , two out of them were used the pictures of other sheets. the result was filenanme were ok but pictures were of other sheets.
