Draft Module PDMS V12 DRAFT - very slow
  • Replies 21 replies
  • Subscribers 5 subscribers
  • Views 5 views
avwf_quickdraw1970100
avwf_quickdraw1970100 over 14 years ago
  • Neil Dryden
    Neil Dryden over 14 years ago
    Does anyone know what "quickdraw-1" means by "label pallete" ?
  • Neil Holmes
    Neil Holmes over 14 years ago
    [QUOTE=quickdraw-1;45671]hi codooaustin
    The problem was resolved.
    It was the Label pallette everytime i activated it it slowed down the whole draft session.
    PDMS admin picked it up and tweaked the Label pallette now its running great.
    cheers
    Happy no more hourglass
    There can be a performance problem in the navigator if you have multiple licence file servers in your LM_LICENSE_FILE environment variable.
    Every time you navigate it does a test to see if you have a final design licence, if you have servers that aren’t visible in your environment variable it takes about 3 seconds every time you navigate in the tree view.
       !session = current session
       !license = !session.finalDesigner()
    In one of the later SP release for 12 (not sure which but I think its SP6) this has been changed to check a variable rather than execute the command which speeds it up. The only problem is, the fix has only been applied to the navigation in the tree view, if you use the popup menu on the tree view it still uses the above, so can take several seconds display the menu!
    To get around it you need to make sure you have only one server in you environment variable or modify the relevant files so that if you don't have final designer (not sure how many people do have it) the variable !license is set to false.
    Neil
  • Ilgiz Kalimullin
    Ilgiz Kalimullin over 14 years ago
    Really 12.0SP6 on Windows 7 works well!
  • Cody Austin
    Cody Austin over 14 years ago
    Glad to hear that!
  • Anand Kalathil
    Anand Kalathil over 14 years ago
    DRAFT is checking the license for "final designer" for some reason. This is slowing down DRAFT
  • Shaun Clough
    Shaun Clough over 14 years ago
    Sorry if this is a bit off topic, but any idea if 12 will work on XP 64?
  • Cody Austin
    PDMS 12.0 does work on Windows XP 64-Bit edition, although I can't remember if it is supported by AVEVA..  Keep in mind it will run in 32-Bit mode.
  • Ilgiz Kalimullin
    and how to switch it off?
  • avwf_zyrber
    avwf_zyrber over 14 years ago
    Have any tips on running BPM? I set all the parameters but BPM won't run?
  • me_hungry
    me_hungry over 12 years ago
    Hi all, You sad that -
    [COLOR=#333333]Every time you navigate it does a test to see if you have a final design licence, if you have servers that aren’t visible in your environment variable it takes about 3 seconds every time you navigate in the tree view.[/COLOR]
    [COLOR=#333333]!session = current session[/COLOR]
    [COLOR=#333333]!license = !session.finalDesigner()[/COLOR]
    is it possible to delete this request?
