Draft Module From PDMS to Autocad
  • Replies 7 replies
  • Subscribers 6 subscribers
  • Views 9 views
Francisco
Francisco over 14 years ago
  • Francisco
    Hi guys!
    My name is Andrea Font, I´m a piping engineer working with PDMS.
    I´m a begginer and I want to know how to convert PDMS files to Autocad. I´m using Autocad 2008.
    Thanks!
  • Thiago Trigo
    Thiago Trigo over 14 years ago
    You want to export your drawings from PDMS to dxf format?
    If yes, then there are already some threads on this forum about it...
    Draft isn't a very easy module, so you should consider applying for a training course.
    Do a search in the forum and I'm sure you will find what you need.
    Hope it helps.
    Thiago
  • Admin
    Admin over 14 years ago
    Why do you always need to export to 'DXF'....? Why dont you use 'Autodraft? this way you convert draft drawings directly to autocad and edit them as well.
  • Admin
    From Aveva
  • Francisco
    Where could I get Autodraft?
  • Barry Bertram
    Barry Bertram over 14 years ago
    If Draft is set-up correctly that we give you the results you need. Try configuring that a little, no need to use autoCAD
  • eru urfin
    eru urfin over 10 years ago
    Good day. Hope someone can help me.
    I setup everything nicely in draf admin, from symbol, representation, style and label.
    I already put PDMSfont and Autodraft into my autocad 2014. But when i convert from draft to drwg, the result is ugly. All my symbol is not appear in my drwg. All the leader line for tagging not shown. all text have box arround. And line weight is not same. Simply say, the drwg created in draft are not same in Autocad output. Any tips how to solve this problem?
