Draft Module Fatal SPLASH Error
  • Replies 16 replies
  • Subscribers 5 subscribers
  • Views 47 views
Fatal SPLASH Error
Valentin Borsaru
Valentin Borsaru over 14 years ago
  • Atish naresh parkar
    Atish naresh parkar over 13 years ago
    now I am getting the Error in Draft
    while creating the new Drawing
    the application exits as i select the template while creating the new drawing
  • Cody Austin
    Cody Austin over 13 years ago
    [QUOTE=atish;54929]now I am getting the Error in Draft
    What version of PDMS are you using?
    PDMS 12 sp5. fix 12
  • Juan Manuel Gutierrez Valderrama
    Juan Manuel Gutierrez Valderrama over 12 years ago
    [QUOTE=mjt;49903]You've almost certainly got a corrupt picture file - delete it (manually) & recreate by UPDATE PIC, UPDATE DESI, & SAVEWORK. To determine the file name do a Q PICFILE at the Sheet element.
    HTH
    Martin
    Thanks. It solved to me a big problem.
  • me_hungry
    me_hungry over 12 years ago
    Thanks [COLOR=#0000cd]mjt [/COLOR][/U] too!
    I think in my case its coused by server shutdown.
    Juan Manuel Gutierrez Valderrama over 11 years ago
    HTH
    Martin
    It happened to me and with your advice I can recover the sheet.
    It happened because a detail view.
    Thanks
