Draft Module Fatal SPLASH Error
  • Replies 16 replies
  • Subscribers 5 subscribers
  • Views 47 views
Fatal SPLASH Error
Valentin Borsaru
Valentin Borsaru over 14 years ago
  • Valentin Borsaru
    Hi everyone,
    I am receiving the following error when I try to open an existing sheet in Draft :
    Error in SPLASH routine HGETIA Area : 'Draft Area' Error: 8 NWD NWDS is negative
    Fatal error detected by SPLASH forcing to return to MONITOR module
    Could someone help me please?!
  • Martin Tester
    Martin Tester over 14 years ago
    You've almost certainly got a corrupt picture file - delete it (manually) & recreate by UPDATE PIC, UPDATE DESI, & SAVEWORK. To determine the file name do a Q PICFILE at the Sheet element.
    HTH
    Martin
  • Valentin Borsaru
    Hi Martin! Thanks for the advice, this was the cause of the error and our admin solved it.
    Sorry for the late reply.
    Valentin.
  • Sam Anand Joseph
    Sam Anand Joseph over 14 years ago
    I am getting the following error in PDMS draft when I open draft. What is it due to. I have reference to PADD Db of sample project. Please help.
    Error is
    SEVERITY 2 < FAILS > ERROR 68 LOCATION FEGQ4A32 GQUTXE.
    Thanks
  • David Curry
    David Curry over 14 years ago
    Thanks for the tip.  This fixed our problem too.
  • Sam Anand Joseph
    Thanks and it is very helpful tip. Cheers!
  • Ilgiz Kalimullin
    Ilgiz Kalimullin over 14 years ago
    [QUOTE=samjoe3;50442]I am getting the following error in PDMS draft when I open draft. What is it due to. I have reference to PADD Db of sample project. Please help.
    Error is
    Thanks
    Sometimes it causes by wrong fonts-setting.
    Check it in ADMIN module
  • Marcel Prosch
    Marcel Prosch over 14 years ago
    Yes correct, when you use the Draft libraries from the Master Project there is a reference to 2 TT fonts.
    In Admin there is normally just 1. You have to add a TT font (doesn't matter which)
  • Atish naresh parkar
    Atish naresh parkar over 13 years ago
    [QUOTE=mjt;49903]You've almost certainly got a corrupt picture file - delete it (manually) & recreate by UPDATE PIC, UPDATE DESI, & SAVEWORK. To determine the file name do a Q PICFILE at the Sheet element.
    HTH
    Martin
    [SIZE=2]do we need to delete all the subfolders in XXXpic and then recreate by Graphic systemupdate picture
    or how to know which file is corrupted
    [/SIZE]
  • Martin Tester
    Martin Tester over 13 years ago
    So long as you know the Sheet that is causing the trouble you can determine the file to delete by Q PICFILE.
    Do not delete all the folders in XXXpic.
    HTH
    Martin
