Draft Module Idf format
  • Replies 39 replies
  • Subscribers 5 subscribers
  • Views 55 views
Idf format
Sebastian Loyola
Sebastian Loyola over 14 years ago
  • Sebastian Loyola
    my porpuse is only a question if pdms can open idf file
  • Atish naresh parkar
    Atish naresh parkar over 13 years ago
    How to generate IDF file from PDMS ?
    Corrado Galluzzi over 13 years ago
    In Isodraft is known as Transfer File.
    In ISodraft: Isometric-->Standard
    Then you can select if you want to produce an iso, a batch file, a bolt report or.....a Transfer File.
    Hope this can help..
  • Raymond Metselaar
    Raymond Metselaar over 13 years ago
    You would need to edit your Isodraft option file with a following line:
    TRANsferFile  /C:\IDF/$!!CE.Name-.IDF
  • Marcel Prosch
    Marcel Prosch over 13 years ago
    What do you want to do with the IDF?
    I have seen a IDF convertor that can read in IDF files at a colleagues laptop.
    You need to do a bit of mapping but i works pretty OK.
    thanks for your replies
    firstly I was trying to get a knowledge of IDF format and how its supported in PDMS.
    We have received a IDF format from one of our Clients as i opened that IDF file in notepad it shows its created in AVEVA PDMS Isodraft Mk12.0.SP6.7 VCON
    I tried to open these file as per Corrado in PDMS Isodraft Mk12.0.SP6.26 module in Utilities process transfer file I am getting an error as
    Unable to process transfer file: Error
    opening message file T:\12\EAG\EAGdraw\I
    SOMAKER\AREA-400\PIPE\FINAL\/MESS//DC-38
    001-420-01-0.txt
    Usually there shouldn't be problems opening transfer files generated with PDMS.
    It seems it is trying to open the mess file located in a folder in the t:\ drive
    Could you check if you have that location mapped in your PC?
  • Raymond Metselaar
    http://52.178.132.139/showthread.php?t=4685
    [QUOTE=corrado;58569]Usually there shouldn't be problems opening transfer files generated with PDMS.
    corrado
    Client has only forwarded the .idf file
    Do we need to ask the other supportive files from the Client as there is no mess file
    Transfer file usually shouldn't need anything else but itself!
